Not a guru, but I got a 99 vortec run on a pieced together propane set up. I had trouble starting mine the first time because the throttle plate was closed too much and wouldn't let enough vacume through to suck in the propane. I opened it up just alittle and VROOOM VROOM! You might try that, and if its a used set up it could have a dried out diaphram...
the setup is freshly rebuilt (supposedly). Got it from Roy, out of canada, GotPropane.
I can't figure it out. Today i go out, fired it up, it runs great, damn near idles. I shut it down, and can't get it to restart, barely even chokes. I open the flies all the way up to clean it out, and it farts a little, then thats it. It's like the longer it sits, the better it does. Almost like its getting too much pane or something. I need a propane genius to pay me a visit.
Have you tried a diffrent tank? Sounds funny, but mine would start real hard with a certain tank, then when I switched it'd start easy again. And thats all I got, good luck!
double check your solinoid is working and maybe pull the top of the carb off and clean the rubber piece ontop. Then check the nob under the bowl to see if on lean or rich. There is only 3 setting on mine. Other than that, it's pretty strait forward, timing maybe?
Is your regulator icing up???
Check for a rats nest from sitting to long. http://www.impco-beru.nl/IMPCO%20Training%20Manual.pdf Last edited by tinbeater; 07-22-2009 at 10:41 PM. |
Just read through the pirate thread again. You said the longer it sits the easier it seems to try to start, and that only the front 4 cyl seem to be firing. That sounds like you aren't getting enough fuel. Have you checked for vacume leaks? From what I understand a propane system works on pressure from the tank, and vacume from the motor. If the tank is full it has pressure. If there is a leak it might not have enough vacume to open the lock off valve all the way, or even open the diaphram in the mixer.
