Old 07-31-2009, 11:56 AM   #1
JET455
Your wifes pimp!
JET455's Avatar
Looks good Brad very nice job!
Old 07-31-2009, 12:37 PM   #2
Specs? Motor, trans, case, axles, gears, tools spare parts etc...
Looks dent free! You need to come wheeling. ;)
Old 07-31-2009, 01:05 PM   #3
I'll post a "before" picture if I get a chance later.....but let's just say I was called crazy by several people for spending the time to put fresh sheetmetal on it.
1990 Blazer
6.2L diesel, 700r4, 241
110k+ miles (I've owned it since '94 with under 50k), engine never cracked open, trans never touched except for a cooler, t-case never touched) Been wheeled hard for 10 years.
D60 front, new non-neck Spicer inners, 35-spline Yukon stubs, flanges, Lock-right, 4.10.
14FF rear, welded, 4.10's, disc brakes, home-brew beefed diff covers f&r
4" lift springs in front, shackle flip with stock springs in rear
39.5" TSL's on 15x8 rims with 2.75" backspacing
Homebuilt front and rear bumpers, Ramsey 9k winch.
Rockers cut out about 6" high and replaced with 3x3 tube. Doors still fit but required 4" cut out along the bottom.
Cage, line-locks, dual batteries, 140 amp alternator, blah, blah, blah.
Normally have a large box, Hi-lift, shovel, spare driveshafts, 38" spare tire, etc... in the back.
Old 07-31-2009, 02:49 PM   #4
how did you do at the fair???
Old 07-31-2009, 09:11 PM   #5
Nice Rig! A diesel... Bet it sounds good in the woods.
Nice Job on the wrap around bumpers.
Old 08-04-2009, 12:19 AM   #6
The term "bark is worse than the bite" comes to mind with the exhaust. It has dual 2.5" 40 series flows that sound really good IMHO, but it is a 6.2 diesel. It did pull 2nd gear low range in the mud at 3,600 rpm governed speed and thus chuncked mud onto the roof. Engine mods including a J code intake and turning up the pump are coming this fall. Most people think it is a gas engine when under throttle.
Placed mid pack at the fair. I was 4th overall running and didn't get to see how bad the bumps were. Las year they are pretty bad and you had to hit them pretty easy to avoid breaking a stock suspension rig....this year they were much milder and I could have hit them much harder but didn't realize until after the fact, and you only got to run the course once. Think I got around 31 sec. and the winning time was mid-20's. I blew through the mud, but babied it on the bumps/jumps since it wasn't worth breaking it to me.
Old 08-04-2009, 07:10 PM   #7
clarifying question...
"new non-neck (down) Spicer inners"
I thought they quit making those, where'd ya find the good stuff??
Beautiful rig...
