No, Sally just takes his rigs "swimming."
i remember swimming one year at windrock there brad. people who live in glass houses....
#2 | |
One of these days Zuk 2.0 |
2 days after pickup.
Pulled motor to replace throw out bearing and found out that the inputshaft had about a1 inch of front to back play and 1/2 inch up and down play so I replaced it with another w56 and I have a centerforce clutch and pressure plate for it.. For the oil leak the timing chain cover is cracked ( the bolt that goes through the valve cover was tightened to much and cracked the cover so Iam replacing that and puting a new head gasket on while its apart. Was going to put a cam in it but looks to have a new aftermarket cam in it of some kind. ![]() ![]() ![]() ![]() Last edited by bc35339; 08-24-2009 at 10:00 PM. |
good looking buggy, but damn, a 10 bolt and 42's? those axles have to already be living on borrowed times.
I drug a trans and T-case to zooki melt because the previous owners buddy said this buggy needed them. But once I got there they told me he had bought a complete truck and didn't need mine anymore:mad: sounds like he needed them after all...
It is a nice rig though ![]() |
He told me that it was just a throw out bearing making the noise.
O well ill have i lined out in a week or so I plan on putting new skins on it to.Ill take some pics as I go and post them. Question? I bought this off ebay and asked seller about any knowed problems and he said nothing about the oil leak that leaks about that size of the bottom of a 5 gallon bucket in 2 min. of running. What kind of feedback should I leave??? Ive been holding off on doing this not sure on to say anything about it? |
#7 | |
