Old 09-10-2009, 10:08 AM   #1
HumminNBoatin
Like Nothing Else
HumminNBoatin's Avatar
Universal Base Dial Indicator--Rental???
I am planning on installing a front locker in the H2 this weekend however my biggest hang up is not having a universal base dial indicator kit. I need one that uses a C-Clamp as the H2 front diff is Aluminum and the instructions call for a Clamp style base.
Does anyone know of where I can Rent one from? Seems to buy one of these kits is at minimum $100. If I am going to spend $100 on a tool, I might as well just pull the diff out of the truck and take it to someone and have them install the locker.
The Hummer Club Inc.
Director - Events Planning/Ambassador Program
Eric@TheHummerClubInc.com
www.thehummerclubinc.com
HumminNBoatin is offline   Reply With Quote
Old 09-10-2009, 10:12 AM   #2
what kind of locker ? if it installs in existing carrier then dont worry just dont mix your shims up when you take it apart
if not are the bearing caps metal ? i do have a magnetic one if you can possibly stick it to them other wise my aluminum magnet is out for repair
Old 09-10-2009, 11:46 AM   #3
HumminNBoatin
Like Nothing Else
Scotty,
I does not use shims. It has adjustment screws. It is the eaton elocker. and you might be onto an ideal that I had not thought of. I will call eaton to see if they use the same exact carrier for the elocker that is already in my truck.
I think the caps are metal. However the manual calls for measuring the lash via the pinon yoke.
Old 09-10-2009, 11:56 AM   #4
kyrel69
the eaton e-locker is a full carrier locker.
Old 09-10-2009, 12:09 PM   #5
HumminNBoatin
Like Nothing Else
Yeah I just looked at the drawing again and realized there is no way that its the same carrier as my stock unit. For some reason I just had a brain fart to think that it would be the same carrier with different guts.
The bearing caps are metal but I do not think they have a flat surface that would be ideal for a magnetic base dial indicator.
Old 09-10-2009, 12:26 PM   #6
Originally Posted by HumminNBoatin View Post
Yeah I just looked at the drawing again and realized there is no way that its the same carrier as my stock unit. For some reason I just had a brain fart to think that it would be the same carrier with different guts...
Even going with another factory carrier, you'd probably need to reshim.
Scott just meant that if the locker installed inside the existing carrier (lunchbox lockers like my lockrights) you wouldn't have to mess with it.
For what it's worth, gear-setup is one of the few things I just pay to have done...
Good luck with it!
Old 09-10-2009, 03:58 PM   #7
well if you get it out i can set up the backlash for you. the ones that screw back and forth are even easier. toys,zuks,9"fords etc. just let me know.
Old 09-10-2009, 04:06 PM   #8
HumminNBoatin
Like Nothing Else
Call me 513-226-5823
Old 09-10-2009, 06:54 PM   #9
Can you bolt a steel plate to one of the access cover holes... then stick a mag base to the plate?
I've worked on a bunch of titanium and aluminium gear boxes and always did it this way...
I have a 16" reach mag. base that you can barrow ... need a plunge indicator also?
Jeff
Old 09-10-2009, 09:54 PM   #10
I will call you friday (tomorrow) got busy today and ran out of time.
Old 09-10-2009, 11:36 PM   #11
superjeep
Ive got the starret with the c-clamp base and ive got mag ones and a plate
of steel to put magnetic one on.
let me know what you need if you do not find any.
Shawn
(513)617-3942
Old 09-11-2009, 09:00 AM   #12
HumminNBoatin
Like Nothing Else
Shawn sounds like you da man!! What part of town are you in? I will give you a call later today.
Scotty, I still could use an experienced hand for help with this as I really dont want to fock this up lol.
Old 09-11-2009, 11:01 AM   #13
superjeep
I am in Norwood, a couple blocks from Cincinnati Gardens.
Shawn
Old 09-11-2009, 01:04 PM   #14
HumminNBoatin
Like Nothing Else
Just got off the phone with Shawn. Great dude! Thanks I will be over there around 3 to pick up that indicator set! Thanks again man!!
Old 09-11-2009, 10:20 PM   #15
Shawn is ghey, watch your back.
