Old 09-21-2009, 09:42 AM   #1
sounds like the unit is bad.
i have the same one and mine releases right away.
It vfy it is the solenoid. I would turn it on and then turn it off and unhook the air line going to the diff. If the ARB release then. You know it is the solenoid if it does not then it the the ARB it self
That is what I did. Anywhere that I release the air line it releases the pressure and the unit unlocks instantly.
I am going to call ARB as soon as they open up.
Old 09-21-2009, 09:47 AM   #2
kyrel69
Ok just checking
Then yes the Solendoid is not working right. I think they will fix you right up and if they will not I have a place to get cheaper solenoids from that work just the the ARB one's. I will try to fine the link and post it later.
Old 09-21-2009, 12:35 PM   #3
The problem that I had was caused by a reversed solenoid block. my mangled set of directions apparently were destroyed in the area that says port 1-tank, port 2-air line. If this is reversed, it will not vent correctly.
All is now well and +1 for ARB Tech Support.
Old 09-21-2009, 01:53 PM   #4
kyrel69
well at least it was a easy fix for you :)
