Custom fabrication
Thanks for all the input!
How do you guys feel about the waggy REAR dana44? Thats the one where I made the comment about the axle tubes tapering from the center cast housing to the housing ends? I have one of those. Im trying to keep my 8.8 for my daily driver...
Regret not what you've done,Only what you have'nt. |
Waggy 44 rear
The 44 i am running is out of a '83 waggy,which was a very simple swap into my XJ. I am also running a Tom Woods SYE and driveshaft,which is very important in this swap.The 44 is just OK,keeping in mind that you can break anything if you try hard enough.When you wheel with the 'zuki and the 'yota guys you either wheel hard or stay on the porch.
Custom fabrication
any one ever use these?
http://www.reidracing.biz/DANA30.php Im thinking these would be a nice way to go. I just wonder if the axles become the weak link along with the u joints. Its says they are machined to clear the CTM joints...so what do you guys think? i kno wthey seem pricey at 259 each..
Custom fabrication
Yeah im not so sure either..Im still trying to figure out what axle is the best way to go..trying to do all my research as well as asking personal opinons of those who have run d30,d44 with 35" tires..
Thise reid racing knucks looked appealing due to the fact that a good unit bearing is $90.00 and cheapy is $70 so I have replaced 3 sets now..and the fact that the reid racing units use old style 44 bearing that never SEEM to wear out..it seems like a viable option..and you get lock out hubs. I think ARB made a air locker the was a hybrid that used 44 axles and then the weak link would be the gear..im still up in the air...Im thinking a 449 now...a 609 may be another option...ugh..all this thinking is making my brain hurt..lol
Guest
Posts: n/a
You will not have a problem running that rear Waggy 44 axle. Especially with 33-35 tires. I have many friends that run 37s on waggy axles front and rear, and I will be doing the same and have no worries in my axle choice. I would love to go Dana 60s, but for a DD and only running 37s I couldnt bring myself to it.
But to your original question, maybe throw a truss on that rear axle and you pretty much wont ever have to think or worry about it once its under your heep. Plus like someone said earlier in the thread, disc brake conversions for it you can get at alot of places (online fab companies). Also I would see you having a problem with that HP Dana 44 front, especially with 33s maybe 35s. Our trail boss runs a HP Dana 44 from a Ford truck on 35x15.5 SXs and wheels it HAAAARD with no breaks but a 30+ yr old u joint. The 8.8 is a good axle and available almost at every pick n pull as well. Both my step dad and brother run one in their jeeps. I got a set of Waggy Dana 44s for less than a single 8.8 so I couldnt pass it up. Good luck to whatever ya decide! ![]() |
#7 | |
waggy 44's
Those knuckles look sweet and well designed but i can't see putting that kind of money in a D30.Ballistic Fabrication makes a mounting kit that welds onto a D44 that enables you to us all your XJ front D30 componets.Such as control arms,coil srrings,track bar etc.Seems like it is around a hundred bucks.This makes the swap a real clean setup.You'll also need to shorten the driveshaft since the D44 diff is larger.Ballistic Fabrication phone # is 520 888 4441 ,they are in Tucson,AZ. Hope this helps you deside on your axle swap.
Guest
Posts: n/a
