Let me see tonight but I believe it does it on any setting.
could the linksge be installed out of phase ? does it actually park or does it stop where you turn them off ?
One of these days Zuk 2.0 |
I need to look at them closer but I do know that when they turn off they are stopped in the middle of the wiper stroke which puts them directly vertical.
take the linkage off at the motor and the rotate the wipers to your desired position and then reattach at the motor. sounds like someone installed out of phase
01 jeep tj
makes sense
That would be too simple though. I wondered if that would make the wipers run too far in one direction but after looking at the linkage setup I think you have something. ;)
thanks im not a mechanic i just play one on tv
