They are on hummer 8 bolt recentered double beadlock wheels with rock rings. 16.5x9.75. poly inserts
so how do you think the rockers work vs the iroks you had before
They are nice from what limited use I have had with them. The size is too wide for me and they are heavy. The tires sidewall is thicker than comprable tires. Very quiet on the road and do not flat spot as bad as a bias ply swamper. Drive them on the road at 5psi and 35 psi with no problems. Gonna try them out some more and see.
#4 | |
if you decide to step up in size, consider the 42 rockers...I have nothing but good things to say about mine |
Well it definitely looks better without the dreaded hood scoop.
That thing was made from an industrial sized mailbox and .060 steel! First item I removed! Need to coil the rear.
