COMANCHE NUT
Learn it. Live it......... :)
Administrative Code 4501-43-04 - Specifications (A) The horizontal bumper shall be at least 4.5 inches in vertical height, centered on the vehicle's centerline, and extend no less than the width of the respective wheel track distances. Bumpers shall be horizontal load-bearing bumpers attached to the vehicle frame to effectively transfer impact when engaged. (B) Maximum bumper heights shall be determined by weight category of gross vehicle weight rating (GVWR) measured in terms of the vertical distance between the ground and the bottom of the frame rail or bumper. Maximum bumper heights are as follows: Vehicle Type Front Rear Passenger Vehicles 22 inches 22 inches 4,500 lbs. and under GVWR 24 inches 26 inches 4,501 lbs. to 7,500 lbs. GVWR 27 inches 29 inches 7,501 lbs. to 10,000 lbs. GVWR 28 inches 31 inches (C) If the body and/or truck bed height is altered, the difference in height between the body floor and/or the truck bed floor to the top of the frame ail shall not exceed four inches. (Body Lifts) (D) For any vehicle with bumpers or attaching components which have been modified or altered from the original manufacturers design in order to conform with the maximum bumper requirements of this rule, the bumper height shall be measured from a level surface to the bottom of the vehicle frame rail at the most forward and rearward points of the frame rail. (E) The height restriction in this rule applies to the distance from the ground to the bottom of the frame rail under any one or more of the following conditions: (1) A motor vehicle is not equipped with a front and rear bumper. (2) The bumper height relative to the frame rails has been altered. (3) A supplemental bumper has been installed or an addition to the original or replacement has been made.
To cool... Looks like he spotted me a few ..
![]() Nick
what about a maximum?
So if this is all for safety's sake, is there a minimum distance that the bumper must be from the ground, or are all these trucks that drag their frame rails on the ground ok? That seems to me to be not very safe either.
BiggDaddy
'82 CJ-7, 6" lift, stock axles 258, 35x15.50x15 TSL/SX Rustoleum Gray |
There is also a low limit for suspensions !!!
rant on : I just want to throw this out there just for FYI !!! I hate Troopers, as do most other city cops ( or should I say real cops ) Troopers are just over paid ticket *****es that got beat up in high school. ;) Rant off : You need to ask in court if the measurement was done on level ground and ask for proof the groud was level, if that can not be provided the measurement is out and thus the ticket is out. Just the way I'm reading it !!! may not fly in court so don't blame me if it doesn't work. I have worked in Trenton for 15 years and have only seen one bumper height ticket written. That was for a Ford f-350 that was so stupid high that the head lights were even with the top of his garage door ![]() |
Looks like this is starting to be wide spread through Ohio. There were a couple of threads on JU about this in Ohio and both threads got closed. So there are two web sites I will boycott now.
I never got what part of the state he was in, but I know we have one in Kettering. I have never been bothered, but he did pester E. My theory is I have receiver hitches on the front and rear and an extension should work. I'm 24 in the rear and 28 in the front, but the hitch in the front is 25. Mine weighs 4500 pounds and I'm sure I have gained weight to put me over that. So if you get pulled over, you get out and pull out all of your valve stems and let your tires go flat. Last edited by GPER; 11-15-2009 at 12:19 PM. |
#6 | |
You're f'ed if you do and f'ed if you don't. ![]()
#7 | |
![]() I guess it doesn't matter for me since I might lower it some anyway. |
"let's fab some $h!t up!!
n/m
I understand the Jeep thing.......that's why i drive a Toyota. ![]() '91 Toyota truck(3.0 to 3.4 swapped) "F@#k vacuum lines my truck sucks enough!" ![]() |
I know in our club I am only aware of two people getting pulled over and written up for bumper height, and it was at the same time. We were leaving a campground and going to the trails on a holiday weekend and a State Patrol pulled them over in a small town. He was literally parked along side the road waving lifted trucks over, and everybody and their brother drives a lifted truck in that area. The guy was a real jerk and wanted to have the vehicles towed but we finally talked him into letting us go get the trailers. He didn't even actually measure anything, just wrote up tickets.
Both guys protested the tickets and took them to court. Apparently the State patrol guy didn't normally work in that area and had written up dozens of these types of tickets just over that one weekend. The local judge immediately dismissed the tickets as apparently he had pissed off the whole town and the local cops. |
#10 | |
