Well, it doesn't have a big hub nut, like my XJ does. The Ford just has a snap ring and three thrust washers.
No bigass nut on the back, either, so I guess I'm not sure what you're talking about there... I doubt it's the pinion, I tried engaging the t-case again today and it definitely quieted down. I'd think a pinion bearing would get worse when driven. I guess I've convinced myself it is the selectable hubs. Maybe I'll swap em left-for-right to check, before I drop the coin on new ones. Hell, maybe I'll open em back up, and see if I can just change the bearing... Thanks! Robert
Diesel guy
just take off the snap ring and remove them, the hub is held on by the 4 studs on the back, should be ok for a short test
ive heard that the bearing packs are $400 each, hope thats not what it is, but like you said you can switch just about everything side to side to see
2013 RZR S |
I know the PCV valves in the gas engines are good for making a humming sound when they go bad. Dont know about diesel though. Just a thought.
Robert,Have you tried getting all four wheels off the ground and running it in gear?
Humming sound,Sounds like a bearing.. Don't blame ya on not wanting to throw anymore parts at it till you know for sure. I'm home sunday,will be in the garage till the game starts (4:15PM). Stop over ,I got enough jack stands to get her of the ground. Your welcome to stay for the game. Nick Go Bengals! WHO-DEY!!!
