Old 12-06-2009, 06:02 PM   #1
hotrod
Diesel guy
hotrod's Avatar
I'm kinda partial to the ranger platform. Almost all from 90 forward had an 8.8, at least the 4.0 rangers. Though they were only 28 spline, 31 spline rears from explorers are plentiful and cheap and an easy swap. The front D35 was no slouch with the same u-joints as D44's. Don't mess with the 3.0 rangers if you want to build something for trail.
I dont have much expierience with the 3.0l engines, why are they not good for off roading? underpowered? or just a bad engine all together?
2013 RZR S
Old 12-06-2009, 07:15 PM   #2
RD TRCTR
I believe the track difference between a Ford 8.8 and a Dana 30 is about an inch. Adding a spacer on each side takes care of the problems.
If you go Dana 30 up front might as well go high pinion.
I believe Mike Shelton ran a 3.0 V6 in a Ranger truggy not too long ago.
Old 12-06-2009, 08:04 PM   #3
RuffedUpXJ
RuffedUpXJ's Avatar
It's a 5/8" of a difference on each side so a 1.25" total. So you could even run with out the spacers.
Old 12-06-2009, 09:47 PM   #4
I ran no spacers and you could not tell .
Old 12-07-2009, 12:57 AM   #5
hotrod
Diesel guy
hotrod's Avatar
ya, that would for sure be the last thing on my "to do" list is make up 5/8" on both sides
2013 RZR S
Old 12-07-2009, 08:52 PM   #6
It was a 4.0
Old 12-07-2009, 08:56 PM   #7
I didn't say they were bad, just not optimal. The 4.0 trucks are at least as plentiful as the 3.0 trucks. The 3.0 is kind of by itself in compatibility. The 2.8, 2.9, and 4.0 all share the same bellhousing bolt pattern. This has advantages when tranny shopping. The 4.0's have good power.
Old 12-07-2009, 09:06 PM   #8
hotrod
Diesel guy
hotrod's Avatar
ahh ha! i see, that makes since
2013 RZR S
