Old 12-10-2009, 04:57 AM   #1
not sure i would lift it
but thats just me
Old 12-10-2009, 07:58 AM   #2
a toyota at 70??? yikes!!! i would want good seat belts!!!! lol
Old 12-10-2009, 08:29 AM   #3
f4isvt
but thats just me
whys that?
1989 ext cab yota 22re bored .20 over trd cam, trd headers, Marlin crawler front bumper w/stinger, Marlin crawler roll cage, trailgear rear bumper, trailgear rock sliders, richmond 5.29's, and lockright rear, 33 nokian mt's. 10k winch. Rear disc conversion. Chromoly rear axle shafts. Bombproof motor mounts and transfer case mount. Whole lot of rust and scratches.
f4isvt is offline   Reply With Quote
Old 12-10-2009, 08:53 AM   #4
I lifted mine got bigger tires.
I lifted it again got bigger tires.
started flopping over on speedbumps
really was too high and flopped alot.
got pissed off took body lift out to lower it back down.
had issues with steering box hitting body mount ,cause i moved it after the lift and the trans/tcase hitting floor
so after spending hours jacking with the body mount
and days cutting 3'x4' hole in floor, cause i raised the trans/tcase it after the lift ,got it lowered back down.
bottom line is it dont flip as easy as it used to on a speed bump
I would trim fenders if they hit the 33's and move on
lower with a bigger tire always looks better don't you think?
Old 12-10-2009, 11:22 AM   #5
944drsk
1986 4runner
944drsk's Avatar
I have been watching this thread and have a question, I have a 86 runner 5spd and just bought 35" and been told to do 5.29's (per TG) but I have also been told to get 4.88's. I only plan on taking out to the trail (driving it) it's not a DD. I am also gearing the t-case for the trails. What's your opinion? Thanks!
944drsk is offline   Reply With Quote
Old 12-10-2009, 12:47 PM   #6
For trails I would run the 5.29;s personally but it is an opinion. Either I would think will be fine. You running new years day?
Old 12-10-2009, 01:41 PM   #7
i run 38's in my yota with with stock 4.10 gears and dual transfer cases..(mine is trailer queen..never sees the road)...been wheelin that way for 2 years..i like it...its a lil bit high geared but not enough to justify droppin 600-800 bucks on ring and pinions...plus spare 4.10s are easy to get...gearing is a personal opinion type thing i think...fabricator is runnin 38s with 4.88s and gets around real well..it runs good on the road too..
Old 12-10-2009, 04:32 PM   #8
944drsk
1986 4runner
944drsk's Avatar
As far as I can tell, won't be able to run the 4runner, but would like to attend.Had a good time last year.Won't have to leave early this year.The whole gearing thing is kinda confusing, just want to make sure it's steetable.Thanks for the help.
