Old 01-09-2010, 03:36 PM   #1
dj69firebird69
4.0 HO conversion and transmission questions
I have a 1987 Wrangler with the 4.2 and I just bought a 1991 Cherokee with the idea of swapping the 4.0 HO into my YJ. I am trying not to spend too much because money is tight right now so I need to get some opinions on what I should do. If I use the trans out of the XJ it is an AW4 and i will have the CPS sensor and not have to buy the conversion kit for the front crank pulley. But it is a little longer so my driveshafts will be different. But then I have the TF999 from my wrangler which was rebuilt not too long ago but I believe it needs a new torque converter and I would have to buy the CPS conversion kit or make my own opening for the CPS. Or should I buy a different trans all together? If anybody has any suggestions it would be very helpful. I want to get this all figured out before I move any farther on the project. Thanks
dj69firebird69 is offline   Reply With Quote
Old 01-09-2010, 04:43 PM   #2
Sell the YJ. Build the XJ.
Old 01-09-2010, 04:54 PM   #3
dj69firebird69
XJ was wrecked in the front. The kid rearended somebody going 35mph. Its still fixable but I would rather build up my YJ.
Old 01-09-2010, 05:56 PM   #4
jmb8813
01 jeep tj
jmb8813's Avatar
thats a terrible idea (to build a xj)
Old 01-09-2010, 10:51 PM   #5
X2
Jeep cherokees rule....
Old 01-10-2010, 08:51 AM   #6
Sell them both and get a CJ, it will keep you busy.
http://www.cjoffroad.com/forums/default.asp
Go to the 4.0 section, there is a lot of info there for the swaps.
Old 01-10-2010, 10:05 AM   #7
nick
wheeler
I have been in the process of installing a 4.0 in a cj for about 5 years. It is my 2nd jeep. I was just goin to dd this one and wheel easy if my other was down. I cut the cj trans to accept the cps its easy. I would have rather used auto tranny but my transfer was passenger drop. You will have to get a yj water pump or go electric fan. Swap is only supposed to take a weekend. Good luck
nick is offline   Reply With Quote
Old 01-10-2010, 01:22 PM   #8
Originally Posted by nick View Post
I have been in the process of installing a 4.0 in a cj for about 5 years... Swap is only supposed to take a weekend. Good luck
That's good stuff right there...
But I think he hits on a valid point, that the rest of us were beating around:
Putting a computer controlled engine in a rig it was never intended for, is a pretty major undertaking. It's not likely to be quick, cheap, or easy.
Is your 23 year old YJ really worth it?
