01-20-2010, 03:53 PM | #1 |
90 cherokee trans
Does anyone know if a 93 cherokee transmission will work with a 90 cherokee. Please help
01-20-2010, 04:51 PM | #2 |
naxja.org
Very helpful and full of every bit of info you will ever need for a Xj.
01-20-2010, 05:36 PM | #3 |
i'mma gonna say no... for some reason I think its 87-90 (renix stuff) only trannys with the electrical system.
01-20-2010, 06:55 PM | #4 |
No I think i read about someone making it work but it took a lot. Go to naxja and do a search.
01-21-2010, 02:03 AM | #5 |
You'd be better off with Ballou's 88.
(Is that falls through, I've got a high-mile '90 if you're hard up...) Robert
01-21-2010, 05:49 PM | #6 |
difference between trannys
what is the difference between 40le trans and a 43 le trans and can you use one for the other
01-21-2010, 05:50 PM | #7 |
how many miles
01-22-2010, 01:25 AM | #8 |
I think the Jeep's got nearly 200k, I'll check tomorrow or Saturday. I bought it that way, so I'll have to assume it's the original.
01-22-2010, 09:46 PM | #9 |
If both output shaft(shaft before the T/C) splines are the same it should work.
