Carwash will be building around a set of 13' long 6"x6" "H" columns with 7/16" material thickness..
I've seen chassis tables with and without a provision for positioning the diffs...Mikes will handle anything from a tiny comp single seater to a ultra-long southern hill shooter.. |
#2 | |
Well, If i could get a mag drill for a day, I will fill the beams with 1/2 inch holes so i can bolt anything to it need to wherever i need. Until i get a mag drill, I'm going to just drill holes where we need them.
It's gonna be heavy, and stiff, and strong... like my weiner. Will take pics. Of the table, not my weiner, unless yer into that.
Mag drills aren't too expensive to rent, I rented one when I was installing a Matkins frame. Next time I'll build my own frame.
Here is a pic. of a chassis table that I sold, I still have one that is identical. They work great. I just make different jigs for each application that will bolt to the table.
If you can't fix it with a hammer,you have an electrical problem |
just seen a nice idea on offroadfabnet.com. badlands blog,under team shark attack build. them guys have 4 trailor jacks on the corner of the table to level it and move it. table looks lighter, though, maybe 2x4 rect tubing. entire table is maybe 6ft x 4 ft. i may try something like that.
id like to have some type of rails or racks out the front and back to hold axles lower than table level, at their actual ride height. so i wouldent want the table to be too big. want to see mikes setup, because hes built a lot more scratch built rigs, and cause he'll probably have a sigma decal wrap around his table:p |
