Old 02-10-2010, 12:01 PM   #1
if you have control voltage at the contactor but its not pulling in id turn to the coil. is control voltage 24v? ohm out the coil. if 24v, should be 8-10 ohms if infinity(ofl) its a broken coil(open) if less than 8 ohms, its shorted to itself and not going thru all the windings.
Old 02-10-2010, 01:33 PM   #2
OK that's all greek to me... honestly...
where is this coil? i didn't do any ohm readings... just voltage, the ones on the pic....
come take some readings!! hahahah.
