Your wifes pimp!
Snap on all the way on ratchets I use the dual 80 model with the comfort handle. You will never go back to the others. It has 80 tooth gear compared to like a craftsman 20 tooth. Also go for the bent flex head and you will never use a straight ratchet again!
http://buy1.snapon.com/catalog/item....re&dir=catalog
#2 | |
The Craftsman line wrenches flex as you use them. The Snap On's are beefier. |
Like Nothing Else
Husky is the same PITA. You break your ratchet and to into homedepot and they give you an 800 number. Buncha Crap
I started buying Gear Wrench stuff from Advance Autoparts. Its lifetime Guarantee. If it breaks I just take it back in and they swap it out.
The Hummer Club Inc. Director - Events Planning/Ambassador Program Eric@TheHummerClubInc.com www.thehummerclubinc.com |
