woods beater
Is it a miss at idle only or does it stay under throttle? Is your chip running off the shelf tunes or did you get custom tunes burnt for the new injectors? What about the cam position sensor? They are notorious on our trucks for failure, causing a stall or miss. just a thought. Is the fuel filter clean or is it black from oil past the o-rings?
