I have heard very bad things from quite a few peeps about the trail gear joints loosening up almost immediately. Noisy as hell and slacky slop in them.
I agree whole heartedly, whatever you go with, don't skimp.
Bad News!!! I placed an order with Currie today and they called me and said that all Johnny Joints are on backorder until the end of May!!!
![]() Whos joints should I buy now? |
fullwidthxj
Ive been running the Ballistic joints for about a year, on my upper control arm, the only issue ive had is them loosening up a bit, but, you just tighten the preload back down and forget about it, just make sure to keep them greased up
fullwidthxj
if you need them to be adjustable, try these http://www.ballisticfabrication.com/...nt_p_1636.html
ive been running these with no problems, other than a tad bit of slop that i took out when i tightened them back down, basically the same joint as above, just no threaded stud http://www.ballisticfabrication.com/...nt_p_1226.html |
