04-05-2010, 10:34 AM | #1 |
need help with samurai
I bought another samurai and I drove it from home all the way to college about 2.5 hours away. I went to stop and the clutch wasnt engaging. So I tried to fix it on the side of the road and couldnt figure it out. So I need help. Please.
Adam |
04-05-2010, 05:19 PM | #2 |
Broken cable???
04-05-2010, 05:25 PM | #3 |
no.i fixed it.the guy that put it ondid not put it on correct.
04-08-2010, 09:22 PM | #4 |
new issue
it doesnt want to go into gear that easy when i stop and start.sometimes it will go in easily others it needs a little encouragement.
04-09-2010, 12:45 AM | #5 |
either adjustment or i have had dampner springs come loose and bind against the flywheel and cause the clutch to drag and act like its not disingaging. sounds like it needs to come apart and the answer will be obvious.
One of these days Zuk 2.0 |
04-09-2010, 01:49 AM | #6 |
it worked just fine 10 min ago wen i went for a drive.
04-09-2010, 05:33 AM | #7 |
sound like it might be a shifter sheet and getting stuck between gears....
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn |
04-09-2010, 11:34 AM | #8 |
went for a drive today, and was shifting fine.had no problems getting into first.
