Old 04-20-2010, 03:18 PM   #1
BIGRAM
Ready to Wheel!!!!!!!
BIGRAM's Avatar
Don't have a clue what the wheel base will end up at , will find out when everything clears.
Plan is to keep it streetable , thats why I'm going with Radial 37's
It will be locked in the rear and I'm still debating on locking the front.
Prolly have to recenter the H1's and I'm def. looking at rock rings
Once I get the axles under her I'm gonna build front and rear bumpers, rocker protection and a nice flat belly.
I have several different sets of leafs I'm going to be trying but I will probably end up with Dakota leafs in the front stockers in the rear with a possible extra leaf or two.
What is your plans on locking the rear? I know your wanting to build on a budget as I am myself. I don't want to weld but I can't seem to find a spool for the rear.
Also, what are the plans for the CAD? Vaccum sucks, you installing the cable kit or is there a home remedy for this? I have mine slid over in place but I don't like the front shaft spinning all the time or removing the box to release it. Thinking there has to be another way.
1994 Dodge Ram 5.9L SWB
Old 04-20-2010, 03:36 PM   #2
I used a switch to control the air flow and shift fork to engage and disengage the axle up front.
Old 04-20-2010, 03:44 PM   #3
BIGRAM
BIGRAM's Avatar
Was the switch controlling the existiing vaccum or were you using a secondary source? Possibly compressed?
Old 04-20-2010, 04:09 PM   #4
Used existing vaccum from motor. I do not remember which exact line I used but it is achievable with a little time.
Old 04-20-2010, 08:12 PM   #5
BIGRAM
BIGRAM's Avatar
Cool. My vac lines failed me last year and it was aggrevating until I figured out what was going on. It may just be a leak but I don't have much faith in it now.
Old 04-21-2010, 12:46 AM   #6
Huh. I thought I was the only one who did that:
Been runnin it for years. Works great for me...
Old 04-21-2010, 06:24 AM   #7
BIGRAM
BIGRAM's Avatar
No problems? I can deal with that. Thanks for the input fellas.
Old 04-21-2010, 12:54 PM   #8
No problems?
Yeah, but like I said, I thought I was the only one.
Most people seem the hate the disco worse than brussels sprouts.
Old 04-21-2010, 02:11 PM   #9
OK gonna answer a few of the questions , as I have been busy gathering the final parts for the past few days .... first off I need an Astro Van steering box from a 2wd van , anyone got one ?
The rear is a 60
Yes the front is CAD . not worried !;)
I'm going to run a cable from AW direct , just like I had in the wrangler $43.00 and forget it .
I'm welding the rear spiders
The transfer case is going to remain the factory 236GM unit for now. This will at least keep the build a little shorter and cheaper for now . Waiting for a 231C to roll into the yard and thinking of doing a 231/231 Doubler ??????
Old 04-21-2010, 05:25 PM   #10
kingchango
kingchango's Avatar
231/231 Doubler
interesting
01 TJ
kingchango is offline   Reply With Quote
Old 04-21-2010, 08:05 PM   #11
kyrel69
Can you tell me more or let me know when you got this done and I could just come by and take a look at it.
I would like to do this to my truck
Old 04-22-2010, 08:14 AM   #12
Is this the style that bolts on the inside or outside of the frame? I have a GM box from a van that bolts to the outside of the frame identical to a fullsize 80's era truck, but has opposite gearing. I know it's from a van but not sure if it's an Astro for fullsize. (I bought this from a junkyard already off the vehicle not realizing it was a van).
Old 04-22-2010, 08:30 AM   #13
scotty85
build it,not buy it!
scotty85's Avatar
lol yes they do! not me tho,ive been running my CJ CAD on a vaccum switch for years also with no prollems. well,i did have a prollem... i was takin my dash apart and broke the switch. but that was my fault and i still had no prollem with its operation.
the shift assembly on the axle goes bad alot less often than people believe it does ;)
i do like the PTO cable idea as a fix if my shifter ever does go bad.
scotty
85 grand wagoneer(whats left of it)
77 scout II truggy
84 chevy "home made crewcab"
Delightfully Tacky,Yet Unrefined
scotty85 is offline   Reply With Quote
