Old 05-27-2010, 01:24 AM   #1
yeah ! I just can't seem to go anywhere with out the Trenton poe poe finding me !!!
My plan is to run the 37's this year and then step up to at least 38.5's next spring .
Shooting for woods test this week end , got front end parts switched out today still have to play with a few adjustments , test drive tonight was better but not good enough .....
Old 05-27-2010, 08:24 AM   #2
RuffedUpXJ
RuffedUpXJ's Avatar
I believe you are heading to your local spot?
Are those 37's 16.5's?
What you still need to fix on the drive?
Old 05-27-2010, 09:00 AM   #3
Yes they are 16.5's with hummer H1's recentered w/ 3" BS .
Things that have to be done before it wheels :
Front drive shaft
Exhaust run
Cross member clearanced
Going to take some angles off a stock Dodge truck today and then compare it to mine . I think I have to much pinion angle and it is causing my problems.
No bump steer at all , just all over the road and hard to control at any speed .
Things that will get done later as time will allow:
Front and rear bumpers
Rock rails
lights- auxillary and rock
flat belly skid
Old 05-27-2010, 12:34 PM   #4
wha'ts your caster set at?
Old 05-27-2010, 01:04 PM   #5
RuffedUpXJ
RuffedUpXJ's Avatar
Yeah, Sarge if you have too much pinion angle more than likely your caster is too high causing it to be all over the road.
Old 05-27-2010, 02:39 PM   #6
yep , I went down and took some reference notes from one of the City's stock Dodge trucks and on the flat top of the knuckle it's 5* to the rear. I know with out even going home and checking that mine is going to be way off . It will be no big deal as I only tacked the spring perches on . Hopefully I can get it close with out having to turn the knuckles .
Old 05-28-2010, 02:45 PM   #7
Hopefully I can get it close with out having to turn the knuckles...
Check out this guy... if you find that you're this far out... worth turning the knuckles...
Glad that the Centers worked out well for you.... looks good Sarge... This the third or fourth vehicle completed for you before I got back to mine?
:mad: :o :(
