#76 |
Yeah, Sarge if you have too much pinion angle more than likely your caster is too high causing it to be all over the road.
#77 |
yep , I went down and took some reference notes from one of the City's stock Dodge trucks and on the flat top of the knuckle it's 5* to the rear. I know with out even going home and checking that mine is going to be way off . It will be no big deal as I only tacked the spring perches on . Hopefully I can get it close with out having to turn the knuckles .
#78 | |
Glad that the Centers worked out well for you.... looks good Sarge... This the third or fourth vehicle completed for you before I got back to mine? :mad: :o :(
brad ![]() 5.0L | 435 | 203 | 300 | 4.10 | 39.5 Buildup BACK underway... Last edited by KargoMaster; 05-28-2010 at 02:51 PM. |
#79 |
I passed you in Trenton today,and the Jimmy looks real nice
#80 |
Yep , thought that was you , Looked like you had a little fun in the mud.
#81 |
Got the front bumper on it last night , I think it turned out cool ( and from the looks it got last night , so does the general public) .
Also got the exhuast moved out of the way and welded on the new Thrush welded muffler ..... Flowmaster copy for $40.00 at Advance . I think they sound better then a Flow and you can't beat the price. Drive shaft and skid is up today after work. ![]() ![]() ![]() |
