Old 07-11-2010, 10:56 PM   #8
Carwash, what did the standard shift guys do in the tow test? Any idea?
Kevin ('37 Ford) and Roger ('64 Power Wagon) were about the only Manual transmissions... I was very interested in how they would do... With his wheelbase (extended), and LOTS of air in the rear tires (30psi+ is a massive volume of air in a 54" tire), Roger did pretty well (but he later blew a 205 output shaft)... Kevin dropped a rear driveshaft pretty much at the line... :o
Oh, and if you have a 6.32 1st... HELL yes, 2nd gear... but then again, (guessing)the 205 behind the T-18 is only 1.98:1...
