Old 07-20-2010, 10:49 AM   #1
thank you. i was wondering about them just hadnt had the time to look. i have seen 3 98 tjs that the lines were junk on so i dont know if they(jeep)has learned anything from that
thanks again
Old 07-20-2010, 12:17 PM   #2
KennyTJ
The Pirate
KennyTJ's Avatar
The "green" hard brake line stuff at NAPA or any of the parts stores is hand bendable now days and is awsome stuff. You can get long enough sticks to handle any of the single line runs on a Jeep tub. We re-did the YJ and "moved" the lines to a better location than the factory run. Stuff also blows away the cost of the pre-bent lines as well.
Just my 2 cents worth.
Old 07-20-2010, 12:37 PM   #3
yes but factoring in the labor cost to do someone elses when you own a business is important....it would probably be cheaper to buy pre bent ones...just my .02
Old 07-20-2010, 01:12 PM   #4
agreed.
Old 07-20-2010, 02:36 PM   #5
yeah in a situation where im doing something for a build or myself i would be looking toward bending and flaring my own because for some dumb reason i actually like doing that but since this is stock and a customer replacement job i will be looking toward the prebent kit but thanks for the input.
thanks scott
Old 07-20-2010, 05:14 PM   #6
I used the pre bent brake lines from 4wdh when I put the new frame under my CJ 10 years ago.
Old 07-20-2010, 08:22 PM   #7
TomH
Gearhead
TomH's Avatar
Also check Inline Tube. They are in the same Michigan area as Classic and offer a lot of the same stuff (SS and Otherwise.) Both are old school good.
Old 07-20-2010, 11:57 PM   #8
The "green" hard brake line stuff at NAPA...
That's what I used to mate my 96 master with my 89 prop valve.
It did bend okay, but I had a hell of a time flaring it. I ended up having to scrape off all the green coating to get a grip on it...
