Old 06-20-2010, 10:58 PM   #1
It's Alive!!!
Finally got my sloppy jalopy out of the garage, and I just HAD to show it off:
Ain't she sexy?
Old 06-20-2010, 11:22 PM   #2
Looking good Robert.
Old 06-20-2010, 11:43 PM   #3
Thanks.
I've still got just a couple of bugs to work out, but I'm flat thrilled with how it turned out.
Old 06-21-2010, 02:32 AM   #4
looking good brother...
Old 06-21-2010, 09:14 AM   #5
RuffedUpXJ
RuffedUpXJ's Avatar
It's too bad its so shiny, Haspin will ruin that rolling in to the parking lot.
Old 06-21-2010, 09:15 AM
RuffedUpXJ
This message has been deleted by RuffedUpXJ. Reason: Double post
Old 06-21-2010, 12:04 PM   #6
x2
shininess soon to be wiped off it's face... like the smile of a crook that just got caught.
Nice job!
Old 06-26-2010, 04:35 AM   #7
Well, after fighting the brakes for a few days, my shiny new engine got me all the way to work Thursday:
...but only halfway back home again:
Apparently that romp-stompin renix was just too much power for the rear ujoint:
Old 06-26-2010, 05:07 AM   #8
Rotten Friday Recap:
So I caught a cab the rest of the way home, hooked up the truck and trailer in the dark to fetch the XJ. By then it was nearly 1am, so I didn't bother to unload it.
Bright and early Friday morning, I borrowed her Exploder to run to Smyth's for a new joint. When I got back, I decided not to push the damaged shaft any more, and just do the repairs with the jeep still on the trailer.
Unfortunately, once I pulled the shaft, I found that the ears were pretty banged up:
I wasn't sure if I should reuse it, so I went to install my spare shaft.
That's when I discovered that the spare driveshaft I've been carrying for two or three years was at least three or four inches short. Wish I could remember who sold that to me...
So I thought I'd just use the 4x to get the rig off the trailer, using the front axle. Of course, my old 231 refuses to engage unless I'm rolling about 2-3mph, so try as I might, that was another no-go.
Sooo... I pulled my front shaft to install it in the rear. Got it bolted back in and... (wait for it) the g@&d@##*& jeep wouldn't start.
Sooo... I traced it to a sticky starter relay. The starter relay, mind you, that I really WANTED to replace when I did the engine, but the partsdrone at Advance couldn't get me the right one. So I cleaned and reused mine.
I smacked it around some to free it up (and relieve some stress) and managed to fire it up and limp the thing back into the garage.
I dropped the trailer so i could get to work an hour early, for an oh-so-important safety meeting where they could inform us that hexavalent chromium is, in fact, bad for you.
Then an hour dismantling a nitric acid line, and six straight hours on an 8' ladder, in a 120* building, rebuilding a hot oil valve.
Some days it just doesn't pay to get out of bed.
Edit: (As a wise croc once said: "You geet bad job, you geet bad wife, you die. Beer you only friend.")
Old 06-26-2010, 09:48 AM   #9
Sounds like you have been talking to Peter over at Kings.
Old 06-26-2010, 02:29 PM   #10
Nope, Pearls Before Swine last Friday...
Old 08-14-2010, 03:26 PM   #11
I've still got just a couple of bugs to work out...
It turned out to be more than a couple, like an entire month's worth, but I finally got it out to get a little dirt on the tires last weekend:
And my new wallpaper:
Old 08-15-2010, 11:26 AM   #12
Great to hear your rig is running again. It looks good....Man ,you spent alot of time detailing the engine compartment.
Let's Wheel
Old 08-16-2010, 12:12 PM   #13
Thanks.
Honestly, I spent way too much time detailing: I missed a whole lot of wheeling!
Time to make up for lost time!
See ya Sunday!
Old 08-18-2010, 12:49 AM   #14
comanchedude
COMANCHE NUT
comanchedude's Avatar
- looks good,, i like
