or go to greg hauck in fayettville and tell him you need an add a leaf kit for rear of a half ton chev truck..take out a similar length leaf from your pack and add the add a leaf and rock on...i used to run blocks when wheelin...seen a guy toss a complete rear axle housing and all out the back on the side of a hill...its not a fun trip out...dont run blocks..
#2 | |
Do you know if this guy broke the spring, or just spit out the block? I don't think either is as likely with my version, but we'll see... Robert
So here's what I came up with:
![]() 2x2 box, .250 wall, about 24" long. 30* cut at the leading edge, 45* at the other. On the topside, there's 1/2" hole accept the springs' center pin, and a 1/4" hole at the front to mount the rubber snubber. ![]() On the bottom, I drilled and tapped a 5/16" hole, and used a set screw to position the shim, like so: ![]() ![]() Loosely assembled, pardon the BigRock mud: ![]() In that pic you can kinda see how I redrilled the springplate to move the axle back about 1.5", here's a better one: ![]() Anyway, with weight on it: ![]() And clamped down: ![]() I should have taken a nice nice finished profile pic, but I didn't. I was running out of time to get to work, so I threw the wheels on and test drove it around the block. ![]() ![]() ![]()
Drove it to work, and then the ORFW meeting last night, and it did great.
It obviously lifted me back up to a full 6" lift, which realigned the driveshaft angles, and smoothed out my vibes. But I swear I can feel the antiwrap working, too. When I get on it, the ass end tries to rise a bit as it puts the power down. The ride is a little firmer, but not at all harsh, or even stiff really. Just like it's better put together. They do hang down just a little lower than I'd like. The angled nose should help, but adding a small skid to the front would bridge the gap between the bar and the spring. For a few hours work and a bunch of scrap material, I'm thrilled. I still don't know if I'll keep it long term, but it'll certainly keep me out of the garage till I make up my mind about something better! Robert
looks almost like some old school traction bars.... As long as they don't hang up on everything, i think it is a good fix.... just my .02
![]() chris
Yep, that's exactly what there are: a homemade, offroad version of the old Lakewood traction bars:
![]() That is, of course, why I just had to paint them yella! Robert
Looks good Robert...I'm curious to see how they perform offroad.Yella traction bars bring back some great memories.I had a set on my 69 cougar.
Just a 200 dollar cherokee that wouldn't start .. Ten years later same chrome grille .. Last edited by Coppertop; 09-10-2010 at 03:30 PM. |
