Old 10-20-2010, 09:10 PM   #1
tom tom
tommy
tom tom's Avatar
Send a message via Yahoo to tom tom
Heat
Ok I Had heat the other week now i dont check fuse its fine. Is there a relay under ther hood any info will help thanks tommy:confused:
08 jeep Sahara soon to be with 33s
tom tom is offline   Reply With Quote
Old 10-22-2010, 04:57 PM   #2
tom tom
tommy
tom tom's Avatar
well i been checking everything i know i guess no heat
Old 10-22-2010, 05:57 PM   #3
f4isvt
are both lines of your heater core hot
1989 ext cab yota 22re bored .20 over trd cam, trd headers, Marlin crawler front bumper w/stinger, Marlin crawler roll cage, trailgear rear bumper, trailgear rock sliders, richmond 5.29's, and lockright rear, 33 nokian mt's. 10k winch. Rear disc conversion. Chromoly rear axle shafts. Bombproof motor mounts and transfer case mount. Whole lot of rust and scratches.
f4isvt is offline   Reply With Quote
Old 10-23-2010, 01:25 AM   #4
air pocket? you might try bleeding/burpping it.... Is there some kind of heater control valve that might not be working?
good luck
Old 10-23-2010, 03:37 PM   #5
tom tom
tommy
tom tom's Avatar
both line are hot im going to change antifreeze to see about air pocket
Old 10-23-2010, 03:38 PM   #6
tom tom
tommy
tom tom's Avatar
all valve seem to be working
Old 10-23-2010, 03:40 PM   #7
there is a cable attached to the temp selector. Make sure the cable is still attached and moving freely
Old 10-23-2010, 06:45 PM   #8
dan
gotta love middletucky
dan's Avatar
bring it by and ill give you a hand
98 xj 4.5" lift
Old 10-27-2010, 08:17 PM   #9
tom tom
tommy
tom tom's Avatar
SO ME AND DAN TOOK A LOOK AT MY BLOWER AND I WAS GOING TO GET A NEW ONE WELL TODAY I WAS DRIVING AND AS I WAS DRIVING THE HEAT WAS WORKING BU WHEN I STOPPED AT A RED LIGHT IT WOULD STOP BLOW HAS ANYONE HAS THIS PROBLEM BEFORE
Old 10-27-2010, 09:35 PM   #10
is there any corroded wire connections or maybe a broken wire inside the covering?
sounds like it's just something silly... always the hard ones to find...
Did you try jumping 12 volts to the blower to see if it would stay working?
Old 11-01-2010, 11:16 AM   #11
jfiscus
jfiscus's Avatar
sounds like a bad blower motor...
I assume that when you say "no heat" that it is not blowing on any temperature setting? If the blower is not blowing, try hitting it with soemthing (dont break it) while it is supposed to be on. If it starts working it's going bad (similar to a starter with a bad spot) and needs replaced asap.
Old 11-05-2010, 02:44 AM   #12
Force 10
Force 10's Avatar
Are you certain the fan is running at highway speeds? It could feel that way if you have the fresh air vent open drawing in oputside air. Relays can go bad, or it could be something already mentioned.:confused:
2000 Xterra, ARB Bumper, 2" bl, Wrangler MT/R's 32x10.5, Loadwarrior
Force 10 is offline   Reply With Quote
Old 11-05-2010, 08:40 PM   #13
tom tom
tommy
tom tom's Avatar
iM GOING TO PULL THE BLOWER OUT OF MY 94 TO PUT IN THIS WEEKEND OR MONDAY SINCE I HAD TO WORK AND MISS THE TRIP TO ROCK ON THE CORE WE WILL SEE
Old 11-18-2010, 09:41 PM   #14
tom tom
tommy
tom tom's Avatar
where is the blower relay located on my jeep it is a 95 yj:confused:
Old 11-19-2010, 12:14 AM   #15
Just a guess but I am going to say passenger side behind the dash next to the blend door.
