Nice, I like the fact you using a small block motor. I thought most the other smith buggy's out there are BB. A good high HP SB that rev's higher/faster than BB should do pretty well with such a light weight rig. nother question, Did you, or are you, doing all the figuring for the 4-link? from what i hear the key is getting the math down just right to get a 4-link to work well. Is Jimmy giving ya some pointers on how to do it, orr how he uasally does it, or whatever?
no most jimmys buggys are small blocks 383, 406, he had a fourseater with a 434 in it. I doing four link, i hav built quite a few rigs suspensions and he pointed out few things to help out. got few things today and got front suspension tacked in place
do you have anymore pics of the upper link frame mount? is that one piece you bought or did you have to box 2 together?
it is the 22.5 degree 1.75 mount from polyperformance modified to fit frame
where that battery box come from?
battery box, heims and 3/8 tabs came from ruffstuff speciaties
Looking good man!!! I'm liken the four link set up, looks nice clean work. I must of been mistaken, i was thinkin they ran alot of the 502's, Maybe i'm thinkin of coleworx.. Maybe you said it, and i didn't read it, but you building the propane set up, or is it a kit from somewhere?-Chris
Are the motor mounts hard mounted?
sure you have enough vertical seperation on the frame end? looks like its going to want to lift under throttle? on 2nd look, maybe it is just the camera angle?
