Project Coppertop Axle Swap
Picked up some axles yesterday.Even with the snow falling and the ground a snow/muddy mess ,I manage to cut the axles out.
![]() Dana 44 front and Dana 60 rear out of a 1979 F250. Paid 300.00 :) Now ,let the adventure begin..... ![]() Nick
nice... I bet you'll sure miss those 7 minute Dana30 axle changes, won't you?
Great deal on the axles....hopefully by spring I'll be doing my yj.I'll be following this one for sure
#5 | |
![]() For sure,Already been researching..Thinking bout these... http://bluetorchfab.com/store/advanc...42u0&x=10&y=11 The build sheet is in the works. Nick
lky13blazer...if you are going to do the same to yours then i have a '79 ford rearend that you will want. $100.00 and it's yours. it is complete.
thanks I'll keep it in mind but it will be at least after the first of the year before i get to...do you know the gear ratio? and bolt pattern?
Build List Part one
The build list so far...
Clayton front axle bracket kit. http://claytonoffroad.com/product_in...products_id/83 6.5 Lift Rough Country Long Arm Suspension Kit http://www.roughcountry.com/jeep_xj_6xla.html Blue Torch Fabworks http://www.bluetorchfab.com/store/ Dana 60 rear Disc Brake brackets ( BTF11021) Rear Spring Perchs (BTF11016) Rear Diff Cover/truss DYI Kit (BTF11076) Front Diff Cover/truss DYI kIT(BTF11074) Both front and rear trusses will be homebuilt. Thinking about KM2 35's Tires and these beadlocks(Trailready)http://www.4x4groupbuy.com/store/tra...65-p-8463.html Gears will be 4.88's with a Front ARB locker and rear Detroit. More to come...All comments welcome. Heck ,I wanna do it right the first time. ![]() Nick
#9 | |
8 lug, 3:54's
The Pirate
If your gonna run beadlocks i'd get some serious offroad tires in a bias ply for strong sidewall. Something like a TSL. I run 36" TSL SX's and they are awesome with like 2psi in them. I would NOT run a radial tire sidewall in the rocks, you'll go from changing D30 axle shafts to replacing $200+ tire every trip. I run 35" BFG AT's on the street, great snow tire for on the highway also! with 6" lift you'll have plenty of room for a 36" and the axles are no problem.
Just my 2cents. ![]() |
I love the KM2s. Outrageously priced though. To get the size I want is around 3 grand for 4.
#12 |
I like the TSL's too..But ,I need the best of both(Good street /trail tire).Still kicking around the bigger size tire(36).It's amazing how the price goes way up when you get larger than a 35..
#13 | |
#14 |
my old 36'' iroks always amazed me how well they did on the street. they were bias, and unbalanced would run 80 mph down the highway smooth as silk.
#15 | |
The Pirate
![]() Now back to the op.... sorry! |
#16 |
Pitbulls have worked well for me but are damn heavy!
#17 |
Like Nothing Else
I had the 37" BFG KM1's and they sucked for sidewall strenght. I replaced them with toyo M/T's. Knock on wood the toyo's have NEVER had any problems on or off road. They even run better down the highway than my
KM1's did. The side wall on the Toyo is like 3/4" thick. I also think the Goodyear Kevlar mtr is a good tire to look into. You are not kidding on tire prices skyrocketing once you get to 35 and beyond...
The Hummer Club Inc. Director - Events Planning/Ambassador Program Eric@TheHummerClubInc.com www.thehummerclubinc.com |
#18 |
Axle mounting kits ordered
After a few hours of research...I found three good front axle kits .(Clayton,Rubicon Express,and T&T Customs) I decided on the T&T.
http://02ea137.netsolstores.com/fron...ngstyle-1.aspx I like the truss design (should save me a ton of mock up time),so simple even I can set it up. The rear axle will have T&T'S u-bolt eliminator kit. http://02ea137.netsolstores.com/u-bolteliminiators.aspx My plan was to run a ladder bar(to prevent axle wrap)I understand ,with this design it will prevent axle wrap ..Again saving me time and money. Nick
#19 |
a competition compound trepador is prolly the best tire on the market but they are strictly offroad tires. km2's would be your best bet IMO.
#20 |
#21 | |
#22 |
#23 |
Heck of a deal...
#24 |
Thinking about buying one for a spare
#25 | |
