Old 01-06-2011, 09:49 PM   #1
Haddix505
Haddix505's Avatar
Come on Humpy, how'd u have ur alt. Hooked up using only one wire?
Old 01-07-2011, 07:55 AM   #2
mike shelton
check all your fuses first. under hood and in the truck. then check all the links at the box near the battery. mike
Old 01-07-2011, 08:23 AM   #3
jfiscus
jfiscus's Avatar
Where is the voltage regulator in this system?
On some it's in the computer itself & can go bad, causing charging issues.
Old 01-07-2011, 10:18 AM   #4
blustroker
woods beater
blustroker's Avatar
sounds like a fuse or a bad ground. also check the wire harness from alt to underhood distribution block.
85 toyota ex cab a few goodies
blustroker is offline   Reply With Quote
Old 01-07-2011, 12:38 PM   #5
I had a 81 Toy with the same problem. Everything tested good, even the fuses. Found out by chance that the fuse was sitting exactly between the contacts without touching them. I bent the tabs over a little, and problem solved.
Old 01-07-2011, 07:00 PM   #6
I also have seen an alternator test good and replace it and it was all better.
Old 01-07-2011, 08:53 PM   #7
simpletoy
I have checked fuses all are good. I have also researched this and I beleive it is the voltage regulator also. All grounds are good and on clean metal. No loose connections on the battery. I was trying to get maybe a few more ideas before I spend 60 bucks on a voltage reg. that I may not need.
