Old 01-16-2011, 10:45 PM   #1
flatlander757
Fartface extrordinair
Originally Posted by CJsOffRoad View Post
I have a double ended ram from surplus center that accepts the same clevis ends that PSC sells for heims or you can screw 3/4" heims directly into the ram. I like the surplus center rams because they have mounting blocks welded to them. Don't have to worry about the clamps coming loose. The single ended tractor rams with the big clevis end will get slopply. If you plan on driving your rig on the road I would suggest calling PSC and getting a complete kit from them with a return to center orbital valve.
Sweet, I'll keep that in mind
Old 01-17-2011, 07:17 AM   #2
Jonesy
Jonesy's Avatar
For the orbital valves how are they classified. I see that they have a cubic inch number associated with them. Is this the amount of fluid displaced per one revolution? How many turns do I want/need lock to lock?
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 01-17-2011, 11:47 AM   #3
flatlander757
Depends on how much fluid your pump puts out and how large the ram is.
Read Billavista's article ;)
