Old 01-28-2011, 02:50 PM   #1
Green Zuggy
Green Zuggy's Avatar
Images: 231
its wider than the 79-85 by 3" you would be using spacers on front then.
a good rear axle for sammies are 79-85 unless you plan on doing a front and rear toy swap.hope this helps.
Instead of spacers you could also go with a Rock Assault Axle from Trail Gear to get the 3" wider front to match the IFS rear.
Jeff
