Ready to Wheel!!!!!!!
This may or may not work for you. From the buggy world.
http://www.appletreeauto.com/PARK-LOC-HYDRAULIC/ a couple different apps, good luck.
1994 Dodge Ram 5.9L SWB 3/4 axles, 39.5 IROKS, HYDRO assist |
try - www.surpluscenter.com
Flatlander, that is quite the setup sounds like..it sounds simular to cutting brakes...
for the record, ihad the comp style cutting brakes on my last one and cant say I was impressed w it, trying to go with a true line lock, or preferably a manual style for now... Want front an rear dig capability, but cant cough up the coin for a air shifted case, so im stickin with the atlas. While it is syncronized, u gotta bemovin slow or sttopped anyway, so I think ball valve or ll be my choice. .also I cant fit a two pedal brake cause of tightness. Wish I could.
Big ram, that looks like would be perfect... Not what I had in mind, ...probably a lot better actually! Sarge im having tough time on surpluss site search but it may be there..
#5 | |
#7 | |
I think they are designed to release when you hit the brake pedal.
