Old 02-20-2011, 10:07 PM   #1
Try a pressure bleeder if you can get access
Old 02-21-2011, 07:59 AM   #2
Hotwheels
Hotwheels's Avatar
I have power bleed the brakes on my 4runner. The only thing I can think of at this time is I am using my stock ABS master cylinder and the rear part of the master is to weak and I need to change it to a non ABS master.
Old 02-21-2011, 06:11 PM   #3
Hotwheels
Hotwheels's Avatar
So here is what I did today with the brakes. I have a 1" bore non ABS master cylinder on my 4runner. I have no proportioning valve and no 10lb residual valve on it at all. Took it all of to make sure it was not them. The runner had rear ABS and it is not hooked up at all. I have speed bleed the brakes and 2 person bleed the brakes and still have a ****ty pedal with the truck off and it goes to the floor when it is running. I am so fing pissed at this thng. I have also call sky and talk to someone there and he told me that everything I have done they would have done. So I am sunk any help would be great.
Rob
Old 02-21-2011, 07:55 PM   #4
pfreer3
Old Newb
pfreer3's Avatar
When you bled them, did you do the farthest away first (Left rear, right rear, right front, left front) to make sure you got the air out?
check your vaccum booster check valve (in the line) to the intake manifold. If you took it off and flipped it around, that might cause the sinking pedal when its running. it has a direction so that once manifold pulls a vaccum, the valve holds it. I've seen this problem on 2 different rigs that had poor brakes after the conversion.
Is this a new master cylinder? If not, the one you have may be bad.
Brakes are pretty simple...
Old 02-21-2011, 08:29 PM   #5
Hotwheels
Hotwheels's Avatar
The vaccum valve is fine I never took it off, it is holding vaccum. The master is new and yes I bleed the brakes the right way from passangers rear, drivers rear passangers front, and drivers front.
Old 02-21-2011, 08:44 PM   #6
I have seen bad MC's even though they were new. Ask FlxRtd:o
Old 02-21-2011, 08:56 PM   #7
Hotwheels
Hotwheels's Avatar
I tried the master that was on my runner that was good. it was a ABS master and from what I have read that is not the master I need so i got a new master from Davez offroad performance. I really dont think it is the master.
