Could it be one of Mikes???
http://www.zukiworld.com/month_02010...swithhagen.htm |
Not sure? The housing is aluminum, you can see the mount broke from the housing and has been welded back. I thought it looked like this one, Rear toy 4cyl 8". It is running toy cv shafts and 3 to 5 bolt adapters between them.
Also, it did have the strap over it like he show's on the zukiworld site.
I think 96+ trackers, sidekicks vitaras ect have the 26 spline axles.
Some of the older ones with 16valves should too but you have to pull em to check em. I'd search aroudn and grab a steel housing too. They are botl in and will do away with that aluminum stuff |
Found a 96 shaft, I'll let you know when I get it so I can compare what I have. I'm starting to lean towards the 96+ with the toy cv shafts. Read somewhere online there was a guy years ago that sold an adapter kit for this. Thanks for the help, keep it coming.
