02-24-2011, 02:48 PM | #26 | |
02-24-2011, 03:08 PM | #27 |
For all of you who do not know Hotwheels, he is a good friend of mine and knows his sh** about mini trucks and 4runners. He has also been a Toyota mechanic for about 6 or 7 years now. I talked to him last night and he has done everything you guys have mentioned several times and them some.
pfeer, humpy... I have seen many of these conversions done on the 1st generation runners and trucks as you have and they get done without any trouble. I also know a few guys that have done this on 2nd gen 4runner and had these problems. After talking to Rob(hotwheels) i think he has come to they conclusion it has to do with the 4runners that came with ABS. So all that being said... I hope i have not made anybody mad or steeped on any toes. I am not directing this at onyone in particular. I just thought everybody needed to know that Rob is not a newbie or some one who does not know anything about toyotas... I know everybody is just trying to help, but some just seem to be beating a dead horse... Rant over... Chris
02-24-2011, 03:52 PM | #28 | |
Thanks, Chris |
02-24-2011, 04:00 PM | #29 |
Now get the d*** thing fixed so you can go wheeling .....
02-24-2011, 05:40 PM | #30 |
Believe it's because of the name Rob....
thats the reason that he can't get them to bleed
02-24-2011, 05:57 PM | #31 | |
S10 with a few air shocks.. |
02-24-2011, 06:40 PM | #32 |
x2
I also have a first gen runner with converson and no problems,but as said each toy has a different problem. The new runner i am diong may have same issue as hotwheels. I am glad to see if i do I can fix also. |
02-24-2011, 07:08 PM | #33 | |
02-24-2011, 07:40 PM | #34 | |
02-24-2011, 07:41 PM | #35 | |
02-24-2011, 08:43 PM | #36 |
Old Newb
So if its got a non-ABS booster, what is different? Are the circuits layed out different? Guess I don't understand what COULD be different, unless I look at the brake systems.... I have access to Toyota online FSM for your newer rig, and I have an old 87 manual somewhere. I'd like to know for my own reference.
Didn't mean to offend, you run into a lot of unknowledgable people on forums... I'll kick back a response if I find anything out... |
02-24-2011, 10:34 PM | #37 |
There is no diference between an ABS and non abs booster. There are just dual diaphram and single diaphram booster. The difference is the master there are ABS MC and non ABS MC. your older 4runner and my 2 gen runner are not the same. I will have the bracket made and I bought a GM master today. As soon as to get them on I will let you know the out come.
02-25-2011, 12:05 AM | #38 |
so why not run the master off the older style runner???
02-25-2011, 07:45 AM | #39 |
I am running the master with non ABS 1" bore that is the master that you have to run. Am older master are 13/16 bore.
02-25-2011, 05:45 PM | #41 | |
02-28-2011, 11:42 PM | #42 |
so has this thing been burnt to the ground yet or what????????
03-01-2011, 07:46 PM | #43 |
No, making the GM master cylinder plate hope to have it on Monday.
03-01-2011, 07:50 PM | #44 |
if that dont work see truggy for the needed boombooms to make the problem go away. he likes to blow stuff up.
oh and i hope this works, need to get out and wheel
One of these days Zuk 2.0 |
03-01-2011, 08:11 PM | #45 |
I hate brake issues. Been trying to get good brakes for years. Everything that works for everyone else wont work for you when you try it.
03-18-2011, 08:45 PM | #46 |
Got everything bolted up tonight at work going to bleed the brakes tommarrow morning.
03-22-2011, 09:30 PM | #47 |
Well I got everything bolted up last friday at work but didnt have the time to bleed the brakes because they were kicking me out of work for the night. Today I got all the brakes bleed out with the GM master on my runner. This thing brakes great with the bigger master on it. The pedal is great and everthing is working fine. All I need to do now find out where I want to adjust the proportion valve for the rear brakes.
