Old 06-08-2011, 09:07 AM   #1
jfiscus
jfiscus's Avatar
Pull the trigger with the cover open if it has a cover. See if the feed wheels are turning & in-turn feeding the wire through them. If the wire's feeding fine there then I would assume the liner needs replaced.
Old 06-08-2011, 11:40 AM   #2
you might just be hitting it's duty cycle, and after it cools down it starts working again...
Old 06-08-2011, 12:11 PM   #3
Yeah, if it works and then stops, it's either the electronics are messed up or hitting the duty cycle. It depends on how long you are using it before it stops feeding.
Old 06-08-2011, 12:24 PM   #4
oklahomawelder
Tradin' Fool
THIS^^^^^ would be my bet.....
Old 06-08-2011, 02:24 PM   #5
yea those little welders don't have much of a duty cycle if i remember right.. It should tell ya about it in the manual if you still have it laying around...
Old 06-08-2011, 10:11 PM   #6
did not think of the duty cycle... crap..that might be it, it is a century welder... and lifted the cover and it did not spin the wheels to feed at all..so leaning towards duty cycle.. i know about the kinks int he line and size of wire checked all that .030 is just fine for it..
Old 06-09-2011, 06:35 AM   #7
Nuts's Avatar
Is this the welder I used to have? If so just throw it away and buy a new one because its not worth fixing
Old 06-09-2011, 10:56 AM   #8
oklahomawelder
Tradin' Fool
Its probably about 20% Duty cycle. That is you can weld for 2 minutes in 10 minutes at a set amperage before it will shut off to cool down.....
Old 06-10-2011, 01:58 AM   #9
yes it is...
