Just picturing you getting escorted out has me laughing. Sorry,nothing else to add.
#2 | ||
They were nice about it but they made it clear I was no longer welcome there lol |
Jack it up and take the wheel off ad look to see if the bearing is new or not.
Also when you jacked it up did you jack it up by the lower control arm? If so make sure it wasnt the ball joint moving and not the bearing. If they had it on a lift that could go un noticed. |
x2
That does sound weird. Don't take this the wrong way, but how much play did it actually have? I would say 3" of play in the bearings and there would be more issues than just squealing. It would feel very hot and the brakes would likely feel real spongy as the wobbling hub and rotor would push the brake caliper out. Not debating that something was wrong, but maybe need to look at something else.
#7 | |
Possibly the bearings are now siezed up in a manner that in making the hub not moveable like before when a couple had gone bad & fallen out?
I assume you jacked it back up at home & everything is still fine? I'd guess you could easily visually tell if they'd replaced the bearing or not. As stated above, double-check that it's not another part like the ball joint or something similar that's actually bad... |
