That's exactly what mine does.comes out the defrost when turned on
Diesel guy
I'm not to sure on the vents, honestly never messed with it but ill see what I can find out. IMO steer clear of glowshift. The price is right but why trust a cheap gauge to a multi-thousand dollar rig? I run a quad pod in mine with air pressure (for air horns), boost, pyro, and eng oil temp with isspro EV series gauges. I got em from http://www.kensperformancesolutions.com/home.html good prices and his customer service is great. When I ordered online he called me about half hour later to conferm the order and make sure I got everything I needed. Shipping was very quick too.
2013 RZR S |
Dang their the sane price four three gauges and a pillar.I'm assuming you have to buy wiring harness separate
Diesel guy
I believe you need to buy the Egt probe seperate but call Kenny, he is real easy to talk to and he makes sure you get everything you need.
2013 RZR S |
Ok.sounds good might as well pay a little extra
Mckeddie check to see if your esof hubs are locking in properly and you 4wd is working if not vacuum leak
