Old 07-05-2011, 08:33 PM   #1
Note to self.... Do NOT use E3 spark plugs in a distributorless 4.0. They don't like them!!!!!!
So that was it? Or you tried em and made it worse?
Old 07-05-2011, 10:10 PM   #2
eighty3bronco
anywhere but there
eighty3bronco's Avatar
i was going to try the E3's and all the reviews that i read said that they were junk.... Did that fix your problem??? i have been fighting the same problem for a while.
Old 07-06-2011, 07:34 AM   #3
tjrider
Coppertop told me to try changing them out, and I read some threads about them online. The 4.0s are very sensitive to what plugs you use. Went with a set of autolites and it runs like a champ. Sounds stronger too. So far everything is good
Old 07-06-2011, 08:59 PM   #4
eighty3bronco
anywhere but there
did you have any backfiring when it was having problems. my '99 cherokee will stumble for a few miles unless i go to WOT which i don't like to do since it likes gas then...
i think i might change out the plugs.
Old 07-07-2011, 07:27 AM   #5
tjrider
Yes, when it would jerk and buck I could hear it in the exhaust pipe. If your running double prong plugs, that's probably your problem. It runs 100% better with better mpg too.
