not sure why everyone calls it "reverse rotation"...the gears rotate the exact same way as a standard gearset.
There are "standard cut" gears and "reverse cut" gears. The difference being the direction the teeth are cut onto the gears so they mesh together since one is low pinion and one is high pinion |
