Old 10-13-2011, 12:38 AM   #1
LP78CJ
LP78CJ's Avatar
I have 4 inch trail gear spring in front and 63s in the rear 38s and daily driven no problems with mine at all.
Same setup on my yota and drives just fine.
Old 10-13-2011, 06:11 AM   #2
NKYJEEPSTER
NKYJEEPSTER's Avatar
i will post up some pictures of the spring set up here soon, here s some of what I ve got now. some more info as well.
85 front axle
86 rear axle
36 tsl bias
high steer
trans case regeared to 4.7:1 low
4.88s with lockrite front and detroit rear
22RE
better than stock birfields
ID:	4398   Click image for larger version
Old 10-13-2011, 07:42 AM   #3
Hotwheels
Hotwheels's Avatar
Runner looks good I sent you a PM
Old 10-16-2011, 10:00 AM   #4
reformed
Too many projects
Try a stock sway bar or any junkyard sway bar that is the right width. Make your own end links. I personally have found that I like a rig better when one end of the rig is a little more stable. I don't believe that a super flexy suspension front and rear is always the way to go. Usually seems like the body sways all over the place and the rig is more tipsy. On the TJ that I had I kept the stock rear sway bar, it was just enough to keep the body more stable.
