#76 |
Local 265 work for a contractor installing gas main for duke energy. About to start traveling up to Columbus to install.
#77 |
Retired Air Force Weapons maintainer/loader guy. Worked on 30mm A-10 gatling gun, 20mm gatling gun and all kinds of bombs/rockets/missiles. Also repaired and maintained all weapons related equipment for the aircraft I worked. F-106, OA-37, OV-10, A-10, F-16, F-15, F-111, F-117 and B-52.
01 Grand, 6in lift, 33's, Aussie locked 30/35, front disco's, home made rock rails, Surco rack, grille guard, front and rear hitch, t-max 12500lb hitch winch, rock lights, Mean geen alt, TJ transfer skid plate, OBA and a few other things. Last edited by GCJEEPING; 01-18-2012 at 10:26 AM. |
#78 |
Invisible Dog Fence installer.
Someones gotta keep them puppies safe!! |
#79 |
Mechanical Design Engineer for the company who designs and builds the machines for majority of Procter and Gamble's diaper and paper lines. So Pampers, Bounty, and Charmin are applenty around here.
#80 |
Invisible Dog
I got a jeep |
#81 |
Certified welder, fabricator. Semi tanker inspector/ mechanic. More or less a jack of all trades. If I can't fix it, its broke.......
#82 |
Guest
Posts: n/a
5 year veteran of the us army, Sserved 5 with 3 deployments. Afganstan twice and iraq once. Also been to korea for co op training with the 160th special forces avaition battilion., after being injured I came home and opened a cycle chop closed it down then worked for timewarner business class butas of last Friday I am uneployed laid off.
Specialist ![]() 75th rangers 1st batt. Bravo co. RANGERS LEAD THE WAY, ALL THE WAY! HOOAH! |
#83 |
Well I've been in the auto aftermarket business for 20+ years, window tinting, stereo systems, suspensions etc. Recently started a company doing hydrographics, camo dipping etc.
#84 |
CARPENTER CONTRACTOR for 29 years...even in this market i frame 7 to 10 million in homes a year
