My main concern is I'm not that good at creating an electrical system from scratch. I have no idea where to start wiring this thing up......:confused:
I purchased a electric fan relay kit from OREILYS a few years ago.The kit had everything you needed including the thermostat.The price was under 30.00 bucks.The taurus fan is a great choice.You should have no problem finding one at you-pull since there always at least twenty cars in the yard.
Just a 200 dollar cherokee that wouldn't start .. Ten years later same chrome grille .. Last edited by Coppertop; 02-18-2012 at 04:14 PM. |
http://www.ado13.com/techs/relay.htm
is the relay wiring diagram for the high speed relay. I used a 75 amp relay from ebay. http://www.ebay.com/itm/BOSCH-TYCO-R...-/290499370197 A on off on heavy duty switch and a 20 amp relay from a parts store for the low speed. Both are wired from a switched 12 volt source. The hot side of the relay came from a power block i had from my tbi wiring harness. Get one while you are at the pull and pay. They are on all of the 90's chevy trucks. It made it look alot cleaner when the wiring was finished. Plus gave me a few more hot spots for other stuff Im not a great person with diagrams but there is only 4 wires to deal with per relay. I did have a buddy that helped and once we got started it wasn't bad to do |
Gearhead
That's an HD Truck relay available at Freightliner, Peterbilt, etc. O'Reilly's can get them from their DC, but it's not really a stock item. I have one in the WTF-J and it provides peace of mind knowing that the relay won't cook when I need it most.
I went big on the relay and wire for that same reason
#6 | |
This works I have done 4 like this.
In the diagram it only has 1 relay? Is that right? Couldn't see it real good:confused:
You need 2 relays. One will be for the low side, which is a standard relay that you can get from advanced auto or auto zone. We got ours from an electronics store in Springboro. I can't remember the name of the place but they have a relay and a pigtail to plug into it. The second one is for the high side, which needs to be a high amp relay. We used the 75 amp bosch. If you need a hand let me know. You could bring your jeep over here or I could come to you. I live in Middletown.
#10 | |
Saw this today. It seems easier to wire. Funny a taurus fan and volvo are the same |
Hopefully heading to the wonderful upull tomorrow. AKA: wheelers paradise... So I'm looking for a dodge ram alternator and either a volvo or tuarus fan?..... Might possibly snag an astro steering box for the future front stretch too
Had to look through 10 tauruses to finally find a good fan I can use. It was the last one I think. Picked up a durango 160 alternator to for $20. Not a bad score. Even had it tested and it works! Double bonus
Found a company out of texas that makes a wiring kit with a single sensor for $94. Minus a toggle. Not a bad deal I think, probably gonna order one
No luck finding anything local??
#15 |
Never really found any direct fit harnesses. This one basically a plug and play. Most of the ones around here are "universal", and this thing pulls some juice. So I don't want to be sitting on a trail with a burned up jeep
