I had a few stored codes romoved those, re ran it and it reads its runin lean, gota figure out what's I need to.do to fix that
Dont look @ me in that tone of voice or I WILL PUNCH YOU IN THE SHIRT! :mad: ![]() |
How many miles are it? Does it do it all the time or is it worse when it is cold? The reason I ask is because my truck (1999, 5.3) started with a rough idle when it was cold, and continued to get worse over time and run rough when warm. Got lean codes, misfire bank 1 & 2 codes, yada, yada, yada. Finally narrowed it down to the intake gasket. Super easy to replace. Good luck tracking down the problem.
#3 | |
They call me......Scuba
beat up rusted out k5 |
Yup intake gasket and replace #7 injector while it's apart... It collects the most ****
what type of fuel system are you running?
Just FYI also , the LS motors will run like crap if the throttle body gets dirty , My 6.0 started running rough and stalling at stops. $3.99 bottle of TB cleaner and it runs great, I think I have cleaned everyones TB on my street now
Walbro GSL392 Fuel Pump (External)
Fuel Filter/Regulator 20 Feet of 3/8" High Pressure Rubber Fuel Hose Fuel Line Clamps Adapters thats my set up kirby, http://www.ebay.com/itm/400212661347...84.m1423.l2648
