Old 09-06-2007, 07:49 PM   #1
Shouldn't be spending the night unless I break really bad. The explosions at camp and raging fires usually keep them away at night.
Old 09-07-2007, 06:27 AM   #2
So what's the plan? Who all is going on Sunday? 50% chance of rain, too.
Old 09-07-2007, 06:32 AM   #3
Leavin shop at 8:30 for haspin as long as rain is not falling at that time. I will call Pete at haspin and get a weather update that morning.
Old 09-07-2007, 10:17 AM   #4
xj-up
Jeep XJ
xj-up's Avatar
I might show up If I fix my overheating problem. :confused:
01' Softail
71' Dodge Challenger
Shane
xj-up is offline   Reply With Quote
Old 09-07-2007, 10:44 AM   #5
Any ideas on why it is overheating? Clutch fan or electric? Mud in radiator fins
Old 09-07-2007, 10:52 AM   #6
xj-up
Jeep XJ
xj-up's Avatar
It has a clutch and electric fan. When it started overheating I replaced the water pump and thermo but, still randomly overheats. Jfiscus said maybe air pocket in head to remove temp sensor to bleed air out. Not tried yet. Might pull radiator to inspect.
Jeep 4.0
01' Softail
Shane
Old 09-07-2007, 10:55 AM   #7
Sounds like you have a good plan.
Old 09-07-2007, 07:44 PM   #8
xj-up
Jeep XJ
xj-up's Avatar
Jeep 4.0
Pulled radiator looked ok, I found a small crack in my reservoir. My reservoir is pressurized from factory with no radiator cap. I will try to repair. New one is $40.00
01' Softail
Shane
Old 09-19-2007, 08:26 PM   #9
DinkDavis
Dodge Truggy
DinkDavis's Avatar
check throttle position sensor if it is bad it will make motor run lean thus run hot
DinkDavis is offline   Reply With Quote
