01-23-2012, 10:29 AM | #1 |
Parting out 96 XJ
My son rolled his jeep awile back and we have him back on the road now with another one. It's time to get this roll over out of my yard/shop. There are no straight body panels or glass. They rolled it back up and drove it out of the woods. It wasn't a serious wheeler and had only been out a few times. It was his daily driver and had 190K on it. The motor trans and Tcase all worked great. We are going to part it out now and try to recoup some of the money I loaned him for the one he is driving now.
4.0L motor $250 4 speed auto trans $250 Tcase (NP241?) $200 Dana 30 front (new brakes) $100 Dana 35 rear (Trac-loc) $90 1.5" rear lift shackels $40 1.5" front spacers $40 (still on current jeep, off next week) It has A/C and was holding pressure but was low. No ABS Grey cloth interior is OK but needs cleaned (Wet/glass) If there is anything else you might need let me know, it's going to the salvage yard this weekend or early next week, and anything not priced above is going with it. All prices negotiable and I accept quality Firearms in trade (no jennings or Hi-point please)
There are no stupid questions, but the world is full of inquisitive idiots. |
01-23-2012, 12:52 PM | #2 |
Is d30 a HP and what gear ratio
Romans 7-8 |
01-23-2012, 01:15 PM | #3 |
I will check and post back in a few hours
01-23-2012, 04:38 PM | #4 |
Stock would be high pinion, and 354s...
01-23-2012, 06:31 PM | #5 |
What he said, I checked and it is high pinion, ratio tag missing but BOM tag still there. Numbers as follows:
52060194 55 610502-7 DANA BOM sheet says 1994-1997 XJ Dana 30 front open 3.55 ratio. Axle is still under jeep so I can roll it up on the trailer to take it to the salvage yard. Going to roll it up and then pull it on the trailer and set it down on a couple of wood planks. Should be out by this weekend.
01-23-2012, 07:13 PM | #6 |
How far are you from Dayton, how much for the brake booster, and master cylinder?????? Do you think they would fit my 94 xj?????
01-23-2012, 10:28 PM | #7 |
Dry ridge is 30 minutes south of cincy. I work at the airport during the day. The booster and mc should be the same but match it up. $30 for the pair if you want them.
04-16-2012, 02:14 PM | #8 |
OK, the Jeep is long gone but I've been tripping over the axles, motor, trans and t-case long enough.
$50 each for axles, engine, trans or T-case, they are worth that in scrap.
04-16-2012, 04:09 PM | #9 |
pm'd
04-16-2012, 06:38 PM | #10 |
Front sold pending funds
04-16-2012, 07:22 PM | #11 |
Are the windshield washer nozzles still good?
04-17-2012, 12:21 AM | #12 |
:confused:... for your buggy?
04-17-2012, 08:48 AM | #13 |
04-17-2012, 08:57 AM | #14 |
Jeep is gone, I pulled the drivetrain, sorry.
04-17-2012, 09:02 AM | #15 |
I could use that motor. Can you PM me your phone number?
Just another three linked stretched '95 YJ on 38s with a bunch of stuff scattered on the garage floor. |
04-23-2012, 10:33 AM | #16 |
I need an ac compressor if you want to sell one
04-23-2012, 04:48 PM | #17 |
is the t-case a 231 or 242 ( if the tag on the back is gone the 231 was a part-time only 2hi,4hi,N,4lo case and the 242 has a position for an "awd" on-road 4 wheel drive ( 2hi, 4 part time,4 fulltime, N, 4lo)
04-24-2012, 03:37 PM | #19 |
Still got the motor? i am interested in getting that.
04-24-2012, 07:03 PM | #20 |
I grabbed it the other day. I know a guy in Walton that has another 4.0 though that is letting it go cheap. PM me.
04-25-2012, 04:37 PM | #21 |
Motor is gone, have a commitment on the front D30 just waiting on pick up. The Tcase should be 242, I can check if your serious but have to get back to it in the side storage shop. The trans is standard 4 speed auto. I also have the D-30 rear
04-25-2012, 06:48 PM | #22 |
I am interested in the t-case. No hurry as I could not get to you until after this weekend...busy times.
05-02-2012, 01:45 PM | #23 |
im also interested in the tcase if it is a NP231
05-02-2012, 06:43 PM | #24 |
So...I 'll take it if it is a 242 and Elmer will take it if it is a 231...
If you still have the tranny/converter from it I'd snag that too while I was down there |
