Old 05-04-2012, 12:32 PM   #1
Maybe consider using drilled and epoxied anchors for your sole plate
Not familiar w epoxied anchors...
Old 05-04-2012, 05:43 PM   #2
eighty3bronco
anywhere but there
eighty3bronco's Avatar
If you wanted to keep the same foot print, couldn't you cut out around where the pos pouts were then just pour concrete into the open hole and tie everything together?
Old 05-04-2012, 06:24 PM   #3
Your slab is on top of the ground so the edges could become unsupported with erosion. With all of the weight of the building on the edges it could stress the edge. I would do a footer and do you have building codes that you have to follow and then you have the question. Will insurance insure a building built that way???
