#1 | |
Doing it this way is 10x faster than messing with a Ideal type groover.. |
I'm sure the 1 1/4" wood chisel would be faster for cutting out the small lugs of a Bogger, but for cutting a 1/4 - 1/2" groove across a tread block the groover should be faster. Exact same concept with the exception you don't have to stop and heat up the blade with the torch. I cut a 1/2" groove through the middle of each tread block on my 39.5" TSL's in about 15-20 minutes per tire.
VANILLA GORILLA
Don't b a girl, use a chainsaw........faster than any grover out their. If you have a small battery powered or electric saw its one handed and effortless.
I was looking at something more like this
and not removing an entire lug. |
From your first post I was thinking you where wanting to remove whole lugs to let the tire flex better.
Would cutting a 1/4" wide 1/4" deep groove in each lug really improve flex that much. |
VANILLA GORILLA
O yeah, it adds 100 or so more pinch points per tire.....have you ever seen a late model tire? Thats the principle then air down
